- Jan 6, 2004
- 6
- 0
- 0
Hi all,
For my birthday, I just got a set of Klipsch GMX 5.1 set of speakers for my computer. Then I checked my sound card (a sound blaster live value), and realized it could only handle 4 audio channels. So, I decided to get a new sound card. Not wanting to break the bank too bad, I just picked up a Sound Blaster Live 24-bit, which I thought supported digital audio out. I came home last night, hooked everything up, all drivers installed (I'm using XP Pro), and plugged in the speakers using a minijack to RCA adapter, which is plugged into a digital coax in on the speakers. I thought everything was going great, but when I tested it using creative's software it only put sound out of the front left and front right speakers. Since the speakers have their own Dolby decoder, I thought I'd just try to play something and see what it did. So, I get a emulated Dobly Surround sound, but nothing comes out of my sub. If I run a speaker test on the sub using the controller that comes with the speakers, the sub works great. If I turn off all the emulation on the speaker controller, I only get sound out of the front two speakers.
I guess my question is, do I need a different sound card than the Sound Blaster Live 24-bit so I can get a full digital signal out that will send to all speakers all the time (including sub). I checked around, but I didn't know if the entertainer from maddog 7.1 would be a better fit for what I wanted or not or if I would have the same problems.
(and I did have everything set to use only the digital output).
Thanks in advance,
-Synbios1978
Thanks in advance,
-Synbios1978
