Sound (beep) codes during bootup, where?
My home built PC with an Abit BE6-ii is on the fritz. Within 5 to 6 seconds of power-on, the PC speaker goes into this 2 tone continous whooping noise and boots no further. It doesn't even get the point of synching with the monitor. I've reseated all my bus boards, no change. I cannot for the life of me find the "beep" codes for this board anywhere. I believe the board is telling me something is wrong, but the documentation is not obtainable.
RustyNale
2,220
On a lot of the new boards you have to make sure you have your hs/f hooked to the right mobo connector, sounds like it's telling you that you don't have a fan attached to your cpu. Note: you need a three wire fan (2power and 1 for tach), or the latest bios which will let you turn this feature off in bios.
