System Information
Time of this report: 3/30/2006, 20:44:45
Machine name: OFFICE
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: INTELR
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz (2 CPUs)
Memory: 512MB RAM
Page File: 608MB used, 641MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce4 MX 440 with AGP8X
Manufacturer: NVIDIA
Chip type: GeForce4 MX 440 with AGP8X
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0181&SUBSYS_00000000&REV_A2
Display Memory: 64.0 MB
Current Mode: 1024 x 768 (16 bit) (60Hz)
Monitor: ViewSonic P775
Monitor Max Res: 1600,1280
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.7189 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 4/1/2005 15:16:00, 3980288 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 4/1/2005 15:16:00, 3454656 bytes
Device Identifier: {D7B71E3E-42C1-11CF-A57F-0A2003C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0181
SubSys ID: 0x00000000
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_8086&DEV_24D5&SUBSYS_240317F2&REV_02
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.5100 (English)
WHQL Logo'd: n/a
Date and Size: 2/26/2003 23:03:52, 701676 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D2
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 10:38:44, 57600 bytes
| Driver: usbd.sys, 8/17/2001 14:03:02, 4736 bytes
Gameport Devices
+ Intel(R) 82801EB LPC Interface Controller - 24D0
| Matching Device ID: pci\ven_8086&dev_24d0
| Service: isapnp
| Driver: isapnp.sys, 8/23/2001 00:30:00, 35840 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/3/2004 12:35:44, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 10:44:38, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 10:28:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:01:08, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/3/2004 12:35:44, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
+ Standard Serial Mouse
| Matching Device ID: serial_mouse
| Service: sermouse
| Driver: sermouse.sys, 8/23/2001 00:30:00, 17664 bytes
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Wireless Network Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 135.9 GB
Total Space: 176.7 GB
File System: NTFS
Model: n/a
Drive: D:
Model: DVDRW IDE1004
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 10:29:54, 49536 bytes
Drive: E:
Model: TOSHIBA CD-ROM XM-6402B
System Devices
Name: Intel(R) 82865G\PE\P Processor to AGP Controller - 2571
Device ID: PCI\VEN_8086&DEV_2571&SUBSYS_00000000&REV_02\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 8/3/2004 22:07:42, 42368 bytes
Name: Intel(R) 82865G\PE\P Processor to I/O Controller - 2570
Device ID: PCI\VEN_8086&DEV_2570&SUBSYS_00000000&REV_02\3&13C0B0C5&0&00
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_24D217F2&REV_02\3&13C0B0C5&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 10:38:38, 20480 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 10:38:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/3/2004 12:35:44, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 10:38:44, 57600 bytes
Name: Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_24DD17F2&REV_02\3&13C0B0C5&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 10:38:38, 26624 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/3/2004 12:26:44, 7168 bytes
Name: Intel(R) 82801EB Ultra ATA Storage Controllers
Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_24D217F2&REV_02\3&13C0B0C5&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 00:30:00, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 10:29:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 10:29:44, 95360 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_24D217F2&REV_02\3&13C0B0C5&0&EA
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_8086&DEV_24D5&SUBSYS_240317F2&REV_02\3&13C0B0C5&0&FD
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/3/2004 23:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/3/2004 23:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 12:35:44, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 12:35:44, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 12:35:44, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/3/2004 12:35:44, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/3/2004 12:35:44, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.5100 (English), 2/26/2003 23:03:52, 701676 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.00.0000.0019 (English), 2/26/2003 22:29:26, 47104 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.00.0000.0002 (English), 2/26/2003 23:39:50, 3028992 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/4/2002 21:54:58, 141016 bytes
Driver: C:\WINDOWS\system\crlds3d.dll, 4.12.0001.2002 (English), 11/20/2002 23:07:10, 765952 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 4.12.0001.2008 (English), 8/27/2002 00:23:22, 720896 bytes
Driver: C:\WINDOWS\system32\Audio3D.dll, 4.12.0001.2008 (English), 8/27/2002 00:23:22, 720896 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_24D217F2&REV_02\3&13C0B0C5&0&E9
Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_24D217F2&REV_02\3&13C0B0C5&0&FB
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_24D217F2&REV_02\3&13C0B0C5&0&E8
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&13C0B0C5&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 00:30:00, 35840 bytes
Name: Intel(R) 82801EB PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&13C0B0C5&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 10:37:48, 68224 bytes
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_30441106&REV_46\4&1F7DBC9F&0&28F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 10:40:10, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 10:40:08, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/3/2004 12:35:44, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/3/2004 12:35:44, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 05:46:40, 6400 bytes
Name: NVIDIA GeForce4 MX 440 with AGP8X
Device ID: PCI\VEN_10DE&DEV_0181&SUBSYS_00000000&REV_A2\4&299CCBFA&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.7189 (English), 4/1/2005 15:16:00, 3454656 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.7189 (English), 4/1/2005 15:16:00, 127043 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0016 (English), 4/1/2005 15:16:00, 32256 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0016 (English), 4/1/2005 15:16:00, 32256 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.7189 (English), 4/1/2005 15:16:00, 3980288 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.7189 (), 4/1/2005 15:16:00, 540672 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.7189 (English), 4/1/2005 15:16:00, 5332992 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.7189 (English), 4/1/2005 15:16:00, 5562368 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.7189 (English), 4/1/2005 15:16:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.7189 (English), 4/1/2005 15:16:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.10040 (English), 4/1/2005 15:16:00, 286720 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 4/1/2005 15:16:00, 165039 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 4/1/2005 15:16:00, 55444 bytes
Name: 3Com 3C910 Integrated Fast Ethernet Controller (3CSOHO100B-TX Compatible)
Device ID: PCI\VEN_10B7&DEV_9300&SUBSYS_100010B7&REV_31\4&1F7DBC9F&0&00F0
Driver: C:\WINDOWS\system32\DRIVERS\EL910N51.sys, 2.18.0529.2002 (English), 5/28/2002 22:54:34, 38400 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 00:30:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 00:30:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 00:30:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 00:30:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 00:30:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 00:30:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 00:30:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 00:30:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 00:30:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 00:30:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 00:30:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 00:30:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 12:35:44 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 00:30:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/3/2004 12:26:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 12:26:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:44 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/3/2004 12:26:44 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:44 20480 bytes
qasf.dll: 10.00.0000.3646 English Final Retail 8/11/2004 00:45:04 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:26 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/29/2005 19:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/3/2004 12:26:46 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/3/2004 12:26:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/3/2004 12:26:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/3/2004 12:26:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/3/2004 12:26:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/3/2004 12:26:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/3/2004 12:26:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/3/2004 12:26:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/3/2004 12:26:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 12:35:44 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:58:40 5504 bytes
bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/3/2004 12:35:44 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:35:44 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/3/2004 12:35:44 33280 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:58 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 10:40:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/3/2004 12:26:44 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 10:40:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:18 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:35:44 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 90624 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/3/2004 12:26:48 50688 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:00 51328 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
DMO JPEG Video Decompressor,0x00000000,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
VW AudioConvert,0x00200000,1,1,audconv.ax,2.00.0696.0000
Roxio Quicktime Parser ,0x00800000,0,2,RXQuicktime.ax,1.00.0000.0000
VW AlphaSplitter,0x00200000,1,1,AlphaSplitter.ax,2.00.0696.0000
VW VideoCutList,0x00200000,1,1,vCutList.ax,2.00.0696.0000
DvdDump,0x00200000,1,0,dvddump.ax,1.01.0001.0007
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
NewSoft DV Info Parser,0x00200000,0,0,DVInfoParser.ax,1.00.30929.0001
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
MGI CrossGraph Renderer,0x00200000,1,0,MGICGFilter.ax,2.00.0696.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
VW Pan Zoom Filter,0x00200000,1,1,PanZoom.ax,2.00.0696.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
Roxio MPEG Splitter,0x00200000,1,2,RxMpegX.ax,2.00.0233.0000
ROXIO VCD/SVCD Navigator,0x00200000,0,0,Navigator.dll,2.00.0233.0000
NewSoft Sony MV Multiplexer,0x00600000,2,1,Sony2NSMux.ax,1.00.0001.0005
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VW ThumbnailGrabber,0x00200000,1,0,thumbnailgraber.ax,2.00.0696.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
ROXIO Subpicture Decoder,0x00200000,1,1,SubPictDec.dll,2.00.0233.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Newsoft VOB Writer Filter,0x00200000,2,0,NSFWVOB.ax,1.00.40301.0047
VW SpyPos,0x00200000,1,1,MGINullIP.ax,2.00.0696.0000
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Effect,0x00200000,1,1,claudfx.ax,1.00.0000.0000
ROXIO WAV Dest,0x00200000,0,0,WavHead.ax,2.00.0696.0000
NewSoft AV Sync Control,0x00200000,0,0,AVSyncControl.ax,1.00.40219.0001
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
List Image Source,0x00200000,0,1,ListImageSource.ax,2.00.0669.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
ROXIO MPEG Partition Filter,0x00600000,1,1,PartitionFilter.dll,2.00.0243.0000
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
VW Looper,0x00200000,1,1,Looper.ax,2.00.0696.0000
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
Roxio MPEG2 Muxer,0x00200000,2,1,RoxioMPEGMuxer.dll,2.00.0243.0000
NewSoft Source Reader,0x00200000,0,2,Reader2.ax,1.02.0012.0004
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ROXIO SubPicture Encoder,0x00200000,1,1,SubPictEnc.dll,2.00.0243.0000
NewSoft Sony MV DeMultiplexer,0x00600000,1,2,SonyTSDMux.ax,1.00.0002.0009
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
NewSoft MPEG Audio Codec,0x00200000,1,1,NSM2ADec.ax,1.06.0001.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VW MediaPlacer,0x00200000,2,2,MediaPlacer.ax,2.00.0696.0000
VW Video Effect,0x00200000,1,1,VideoEffect.ax,2.00.0669.0000
VW vlooper,0x00200000,1,1,vlooper.ax,2.00.0696.0000
VW De-Interlace Filter,0x00200000,1,1,DeInter.ax,2.00.0696.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
Roxio MPEG2 Video Encoder,0x00200000,1,1,RoxioVideoMPEG.dll,2.00.0243.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
VW ColorSpace Converter,0x00200000,1,1,ColorSpConv.dll,2.00.0696.0000
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
VW Input Selector New,0x00200000,1,0,InputSelector.ax,2.00.0696.0000
VW Audio Source,0x00200000,0,1,AudioSrc.ax,2.00.0696.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
NewSoft MPEG Buffer Multiplexer Filter,0x00100000,2,1,NSM2SMux.ax,1.00.0002.0009
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ROXIO MPEG Writer,0x00200000,1,0,MGIRawWriter.dll,2.00.0243.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
DivX MPEG-4 DVD Video Decompressor ,0x00800000,1,1,DivX_c32.ax,4.01.0000.3917
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Roxio Audio Decoder (DVD),0x00600000,1,1,RoxioDVDAudio.dll,2.00.0243.0000
NewSoft MPEG2 Splitter,0x00680000,1,2,NSSSpl.ax,1.00.0000.0062
Roxio DVD MPEG2 Decoder,0x00200000,1,1,RoxioDVDDecoder.dll,2.00.0233.0000
MGI Scene Detector,0x00200000,1,1,SceneDetector.ax,2.00.0696.0000
VW Latency,0x00200000,1,1,latency.ax,2.00.0696.0000
NewSoft DeInterlace,0x00200000,0,0,NsDeInterlace.ax,1.00.40628.0001
MGI CrossGraph Source,0x00200000,0,1,MGICGFilter.ax,2.00.0696.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,4.00.0000.2417
CyberLink Video/SP Decoder,0x00600000,2,3,clvsd.ax,4.00.0000.2417
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
VW AudioMixFlt,0x00200000,1,1,audmf.ax,2.00.0696.0000
VW AudioGrabber,0x00200000,1,0,thumbnailgraber.ax,2.00.0696.0000
VW QuickGrabber,0x00200000,1,0,thumbnailgraber.ax,2.00.0696.0000
Roxio SVCD MPEG2 Decoder,0x00200000,1,1,RoxioDVDDecoder.dll,2.00.0233.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
VW Video Resampler Filter,0x00200000,1,1,VResamFilt.ax,2.00.0696.0000
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
Sewer,0x00200000,1,0,MVWcDSutil.dll,2.00.0696.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Roxio MPEG1 Muxer,0x00200000,2,1,RoxioMPEGMuxer.dll,2.00.0243.0000
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
VW Input Selector,0x00200000,1,0,InputSelector.ax,2.00.0696.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
VW VideoInfo Transcoder,0x00200000,1,1,VWVinfoXcoder.ax,2.00.0696.0000
WAV Trans Filter,0x00200000,0,0,WavTransFilter.ax,
MGI DV Scene Change Detector Tee,0x00200000,1,1,DVSceneCDTee.ax,2.00.0696.0000
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Audio Chunker,0x00200000,1,1,Chunker.ax,2.00.0696.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Roxio MPEG2 Video Decoder,0x00640000,1,1,RoxioVideoMPEG.dll,2.00.0243.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
CyberLink DxVA Filter 2,0x00200000,0,3,Cldxva.ax,
NewSoft LPCM Reader,0x00200000,0,2,NsLPCMRdr.ax,1.00.0000.0002
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.2600.2180
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Raw Reader (Async.),0x00200000,0,1,MultiFileReader.ax,1.01.0000.0013
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Roxio Dump Filter,0x00200000,1,0,RxDump.ax,1.01.0001.0007
Roxio Video Transition Filter,0x00200000,1,0,VideoTransition.ax,1.01.0001.0007
Roxio MPEG1 Video Encoder,0x00200000,1,1,RoxioVideoMPEG.dll,2.00.0243.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Video Effects,0x00200000,1,1,vergb24.ax,1.01.0001.0007
NewSoft Smart Reader,0x00200000,0,2,NsSmartRdr.ax,1.00.0001.0006
Roxio DV Frame Detector,0x00200000,1,1,dvframedet.ax,1.01.0326.0000
Roxio MPEG2 Demuxer,0x00800000,1,2,RoxioMPEGDemuxer.dll,2.00.0243.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
NewSoft Source Reader,0x00200000,0,2,reader.ax,1.02.0012.0004
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Roxio MPEG1 Audio Encoder ,0x00200000,1,1,RoxioAudioEnc.dll,2.00.0243.0000
Multi File Reader (Async.),0x00400000,0,1,MultiFileReader.ax,1.01.0000.0013
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VW Video Transition Filter,0x00200000,1,0,VideoTransition.ax,2.00.0669.0000
VW Switch,0x00200000,1,1,MGISwitch.ax,2.00.0696.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Newsoft RT Buffer Filter ,0x00200000,1,2,NSRTBuf.ax,1.00.0000.0023
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.2600.2180
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
DMO JPEG Video Compressor,0x00000000,1,1,,
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX ;-) MPEG-4 Low-Motion,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX ;-) MPEG-4 Fast-Motion,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
NewSoft H.263 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Realtek AC97 Audio,0x00200000,3,3,,5.03.2600.2180
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.2600.2180
Realtek AC97 Audio,0x00200000,19,2,,5.03.2600.2180
