Originally posted by: Kev
Have you tried plugging it into a surge protector. Not sure if that would make a difference, because I have no idea what I'm talking about.
Originally posted by: Juddog
I had a similar issue with my desktop computer. After weeks of messing around with it, ended up being that a floor lamp was causing the issue in another room. The cause is either faulty grounding or faulty circuitry plugged into one of the electrical outlets on that circuit.
Audiophiles run into this issue a lot - basically the cause is some other electrical device on the same line causing the interference. Unless you are willing to examine every electrical device in building to see what is causing this, it's a lost cause. Your best bet is to either run just off of battery or bring a UPS device with you if you need to power a P.A. or what-not.
When I had this issue, plugging into a surge protector didn't make any difference. You would need a professional grade line filter to really make a difference.
