PrincessFrosty
I'm doing video editing with Sony Vegas and rendering out to mp4 and trying to decrease render times by using hardware acceleration, I was under the impression that GPUs ought to be able to render a lot faster?
I have a GTX 980 and CUDA is enabled but I'm getting really long render times which are a bit slower than real time video, we're at 1920x1080 and 30fps. I've followed all the guides to enable CUDA but it doesn't seem to make a difference to CPU only.
Looking at GPU usage its fluctuating up and down between about 3% and 5% which is tiny, and CPU is pegged at 100% for all 8 cores (it's a i7 2600k @ 4.9ghz)
Is this just a case of rendering not being something you can parallelize well? In which case is this low GPU usage expected, or should it be higher? I find it hard to believe that Vegas can only use a few percent of the GPU.
