- Mar 6, 2008
- 51
- 0
- 61
Hello people,
I have a Sony Vaio VPC-SB2S9E laptop and yesterday I decided to take it apart because it was overheating (92ºC on prime95...) and it didn't have dust not even on the fan or heatsink so I followed the service manual which is similiar to an older revision so it is intended for my laptop.
Unfortunely the process didn't go very well because I didn't have a guide to follow the procedure to the end and I didn't feel confortable with the fragility of some plugs and the fact the board didn't want to come off after removing the screws so I gave up and reconnected gently all the plugs on the motherboard, so they are correctly reseated and reassembled everything and put back the screen screwed into the chassis. The problem is that the laptop works but I don't have backlight on the display everything is dark and I don't know what to do I feel kind of in "panic" :/
There was some accidents during the procedure... first while using a plastic flat screwdriver even with a lot of care it scratched the bottom a bit but it doesn't have any circuitry on that place and the other place it was close to one of the ribbon plugs but also it didn't cut anything as far as I can tell...
After that in the bottom close to the daughter board, the plugs covered with an adhesive, when I tried to remove that plug which is a black plastic plug it bent the metal pin contacts (which are so soft like butter or something) fortunely I was able to straight them all and put the plug back in place and then I reassembled everything and it had the same symptoms I described here so I went to that plug again and tried to take it out gently to reseat it but when I did it one of the pins just desoldered and was out with the platic plug so I could reseat the plug and pull that pin making contact with the motherboard... Unfortunely the symptoms continue... The laptop boots and does everything except the backlight on the display. Also I forgot to mention that with all of that fuss of pulling in and out the ribbon that connects the palmrest to the motherboard (sony 073-0201-9364) got wrecked in one of the points since 2 contacts of that ribon just broke a bit...
So what could it be the backlight on my laptop? I feel like I just screwed up a good laptop and I don't know exactly what to do next to make it work again...
And I don't get it since I didn't pince any cable at all I was very careful. I heard that the board has some fuse for the backlight but I don't know what to do or think...
Do you think it's all fixable? Is that common this pc's giving backlight or display problems after reassemble procedure?
Can you help me?
Thanks in advance for your attention and kind help.
Here are the pics of the "broken" plug:
http://postimg.org/image/cajije6e9/
http://postimg.org/image/lyf34u24d/
http://postimg.org/image/z8rdctqoh/
And the actual look of the ribbon cable that I described here:
http://postimg.org/image/xqjgbfm77/
With the best regards,
Rfsapiens.
Can you help me?
Rfsapiens.
