rfsapiens
Hello people,
I've got a very nice Sony Trinitron HMD-A420 CRT 19" Flat Screen with very good and very sharp image but it has a problem which it's the fact of getting persistent magnitising yellow stain on the lower right corner which turns the image in that corner yellowish and "decolourized".
When I shut down the CRT and turn it on again the degauser works and the picture stays clear and perfect for a while but after a minute or so that corner begans to yellow and loose a bit the color again. If I get a speaker magnet closer to that area of the monitor becomes clear again until I take the magnet out...
Also I tried to pass gently in circle motion the speaker magnet and it worked for a while but after some time specially after just turning off the CRT and on after a few minutes the symptoms return to the same spot... Probably I'll have to permanently put a magnet on its side :/
Is there anyway to permanently solve this issue instead of having to put magnets on the CRT?
Also I have another issue with this screen which is excessive brightness and I need to find a way to adjust the brightness to correct values (which is excessive even on zero since the blacks are simply grey) I read somewhere you need some programs, a special cable or to cut a resistor. Can anyone give me an help / guidance with this? Also I need to turn down a bit the red gun on the blacks (although the colors are good and correct the blacks tend to be a bit red).
I think this CRT is still good but how can I fix this thing? I would like to get it fixed to offer it to my mom 🙂
With the best regards,
Rfsapiens.
Rfsapiens.
