Link
Product Features:
# 1280 x 1024 Native Resolution
# 16ms Fast Response Time
# 500:1 Contrast Ratio
# 160° viewing angle
Features
Product Description: Sony STYLEPRO SDM-S73/B
Device Type: Flat panel display / TFT active matrix
Color: Black
Dimensions (WxDxH): 14.5 in x 8.5 in x 16.3 in
Weight: 11.9 lbs
Diagonal Size: 17"
Viewable Size: 17"
Dot Pitch / Pixel Pitch: 0.264 mm
Max Resolution: 1280 x 1024
Color Support: 24-bit (16.7 million colors)
Interface: VGA (HD-15)
Compliant Standards: DDC-2B, EPA Energy Star, TCO '99
Power: AC 110/230 V ( 50/60 Hz )
Power Consumption Operational: 45 Watt
Manufacturer Warranty: 3 years warranty
Technical Specs
Display Type - Flat panel display / TFT active matrix
Width - 14.5 in
Depth - 8.5 in
Height - 16.3 in
Weight - 11.9 lbs
Enclosure Color - Black
Compatibility - PC, Mac
Diagonal Size - 17"
Viewable Size - 17"
Dot Pitch / Pixel Pitch - 0.264 mm
Max Resolution - 1280 x 1024
Color Support - 24-bit (16.7 million colors)
Max Sync Rate (V x H) - 75 Hz x 80 kHz
Response Time - 16 ms
Controls / Adjustments - Brightness, contrast, sharpness, color balance, gamma correction, input select, color temperature, zoom, phase, pitch
OSD Languages - English, German, French, Italian, Swedish, Russian, Spanish, Dutch, Japanese, Chinese
Display Screen Coating - Anti-glare, hard coating
Interface - VGA (HD-15)
Features - Auto ImageSet, ErgoStand, ErgoBright
Image Brightness - 250 cd/m2
Image Contrast Ratio - 500:1
Image Max H-View Angle - 160
Image Max V-View Angle - 160
Analog Video Signal - RGB
Interfaces - 1 x VGA - 15 pin HD D-Sub (HD-15)
Features - Locking device keyhole (cable lock)
Compliant Standards - DDC-2B, EPA Energy Star, TCO '99
Flat Panel Mount Interface - 75 x 75 mm
Cables Included - 1 x VGA cable
Form Factor - Internal
Voltage Required - AC 110/230 V ( 50/60 Hz )
Power Consumption Operational - 45 Watt
Power Consumption Stand by / Sleep - 1 Watt
Software Included - Drivers & Utilities
OS Required - Microsoft Windows 95/98, Apple MacOS, Microsoft Windows NT, Microsoft Windows 2000 / XP
Service & Support - 3 years warranty
Service & Support Details - Limited warranty - parts and labor - 3 years ¦ Limited warranty - backlight - 3 years
Product Features:
Features
Color: Black
Weight: 11.9 lbs
Diagonal Size: 17"
Viewable Size: 17"
Technical Specs
Width - 14.5 in
Depth - 8.5 in
Height - 16.3 in
Weight - 11.9 lbs
Diagonal Size - 17"
Viewable Size - 17"
