Hi,
Well.. I just got my replacement Sony G420S fired up that I got from Dell. My original monitor had geometry problems and an annoying brown discoloration in the lower right hand corner.
This replacement monitor has the same discoloration, but it's not nearly as bad. This monitor also has other problems though. I can't get the image straight. If I tilt the image one way to straighten the top edge, the bottom is crooked and visa versa. The other monitor had this problem as well, but I could straighten it like a crooked picture hanging on the wall. I have no idea how to straighten this one.
The bow on the sides of my original monitor are not present on this one. There were distortion bows about 2/3rd's the way down the side on the other monitor. I had been told that this was normal, but after seeing that this one is perfectly fine, I know now that it was a defect.
There's another huge difference that I didn't notice until about a half hour of using this new monitor. The colors are much more saturated on this monitor than the other one. The blacks are also much blacker. I had complained about the weak text on the other G420 and just chalked it up to being that this was a Trinitron AG and the text was just not as good as a Shadow Mask that I was used to. This was definitely a defect with the other monitor. I double checked the default settings and they are exactly the same as this one.
There are also little nit picky things. There is what appears to be a caulking compound around the edges of where the screen meets the case. There was one little spot on the other monitor that I carefully cleaned, but this one has quite a bit of it. Once again, it's not a big deal, but it shouldn't be there IMO.
Now.. Someone had mentioned that all Trinitrons have the brownish area to begin with and then lose this as they get a little older. I ran the other one pretty consistent for over a week before I boxed it up and it never changed in the slightest. Also, others have said that they had no such problem with the brown area, so I don't know what to believe. I find it irritating. Much more so than any AG grille lines that I thought were going to really bug me considering that this was my first Trinitron.
I just find this whole experience to be very frustrating. Dell has been cool about exchanging the first monitor out. I haven't heard back from them on the second monitor though. It just takes forever with Dell. I've pretty much given up on phone contacts because it takes forever to get through. I've turned to email contact, but it takes a day minimum for the CSR to get back to me. Boy.. They are slow...
Oh.. Someone had mentioned that this brown area might be because of shipping damage. My first box was sort of crunched, but the monitor was unscathed from what I could see. This box was undamaged and with all these other defects, I find it hard to believe that it is a carrier problem. How could I have brown areas in the very same place on both monitors if it was shipping damage? I just think the Sony QC sucks!
BTW.. This G420S is made in Mexico. Wonder if that makes a difference?
Sorry for ranting. I just wanted to let everyone know about my displeasure with Sony.
Does anyone have any other suggestions for a monitor if I can't get this ironed out?
Sal
Sal
