Hello all,
Ever since I upgraded from a Geforce 260 to a Radeon 6950 I'm unable to select screen resolutions above 1600x1200 on my FW900 and I'm not really sure why. I've tried. So I'm stuck at 1680/1050 @ 85hz which is not very nice. If I try to set to 1920x1200 (preferred resolution) I get an "out of range sync" error as the monitor tries to run a refresh rate lower than 50hz? Also, there are no options to actually select resolutions above 1900x1200. I can't manually select the refresh rate @ 1920x1200 as the option is grayed out.
Things I've tried so far:
1. Enabled DDC in the Catalyst control panel but this just forces every resolution at an eye-scorching 60hz and still does not provide all resolution choices.
2. Device manager lists 2 monitors, one plug in play, and the Sony FW900. I've tried deleting both devices and rebooting but they just come back.
3. Updated to the latest AMD Catalyst drivers, didn't help.
4. Installed Power-strip to set custom resolutions but that has failed to work as the custom area is grayed out and no selectable?
Do you know why I'm having such issues with this monitor? Is my video card to blame? I really miss playing Quake Live and BFBC2 at 120hz
My Specs:
Windows 7 64
Unlocked HIS 6950 Radeon.
AMD Phenom X4 @ 3.3Ghz
4GB RAM
60GB OCZ Vertex
Antec 650W Earthwatts.
Any help here would be greatly appreciated.
Thank you.
My Specs:
Windows 7 64
4GB RAM
60GB OCZ Vertex
Thank you.
