Sony G500 settings??
Sully
300
I just purchased a geforce3 video card. Looking at the display properties the refresh frequency is at 60 hertz. What is the best settings for a Sony G500 21 inch monitor.
The setting range is 60-120 hertz. I want to get the best performance.
Bingo13
1,269
Overall 85mhz is a very good setting in all resolutions up to 1600x1200.
I have the G400 and 520GS monitors at this setting. You could do 100mhz but you will probably not notice any real difference unless you game with V-Sync on. Be sure to set your refresh rate at each of the resolutions and color that you typically utilize and adjust the monitor at each resolution change. Windows and the monitor will remember these settings or you could edit the registery.
later....
