Sony FD WEGA TVs: what is"16:9 Enhanced Mode (V-Compression)"?
Twiller
30
Hi...
Many of the newer Sony WEGA TVs are advertised as having a feature called "16:9 Enhanced Mode (V-Compression)". What exactly is this? The salesperson I spoke with didn't have a clue. I assume it has something to do with the wide-screen format that some DVD movies can be seen in. Is that right? Do you need a specific type of DVD player to make use of it? Is it something that's proprietory to Sony stuff, or do other brands also have this feature?
Thank you,
Twiller
kgraeme
3,536
TV screens have resolution just like computer monitors. When you play a widescreen or anamorphic DVD on a traditional TV the image uses fewer lines vertically. The fewer lines, the less resolution. So even though the anamorphic DVD is 640x480 squeezed vertically to 16:9, you aren't getting an actual 480 lines of vertical resolution on a normal TV, you only get about 336 with the other 144 being wasted on the black bars.
Enter vertical compression (or raster squeeze or V-Coompression or whatever people want to call it). On TVs that support this, the black bars of a widescreen image are truly dead space. The scanlines on the TV are compressed down from the 4:3 format to the 16:9 format. This means that you get the full 480 lines vertical resolution, giving better picture clarity.
A good group to talk to about this stuff is over at digitaltheater.com. I know the Sony Wega you mention isn't the only TV capable of vertical compression, but off the top of my head I can't recall what others have it. It's rather new, and likely to become outmoded when true 16:9 TVs become more commonplace.
