I purchased a DSC-S40 as a gift for Christmas. Along with that I also purchased a SanDisk Memory Stick Pro 256MB. For two months it worked fine. Then, a few weeks ago, each and every time the camera was powered on I have received an error message which says, "Memory Stick Error" across the center of the LCD screen in the back of the camera. Along with this message is a flashing memory stick icon in the upper right hand corner and the code "C:13:01"
My first assumption was the memory stick is just acting funky and to try and format it. But the camera won't allow me to do so. When I go to the menu and try, I receive that same error message.
Next, I assumed I had a bad Memory Stick. I pulled it out of the camera to see if the camera would work using its own internal memory. It did just fine, so I concluded the Memory Stick Pro was bad and contacted SanDisk. Seeing as it is only two months old and under warranty they quickly replaced it. Well, the new one arrived today and, lo and behold, that same error message is back! I'm stumped. The likelihood of two bad memory sticks is slim, so I have to assume it's the camera.
Any ideas? Thank you.
