Sony CPD-E200 vs. LG Flatron vs. Samsung 700IFT
kuk
2,925
It has to be a quality 17" monitor. The Samsung is cheaper, followed by the LG and Sony being the most expensive. LG has good support here where I live, this Samsung monitor is new here, and the Sony ... well, it's a Sony.
Which one would you recommend?
Ace69
877
Sony is by far the best monitor that I have ever seen! I have an E400 and it kicks a**! Crisp quality and great dot pitch. I would definately recommend a Sony, that is if you can afford it. :)
Huma
1,301
I find lower end sony's push poor refresh rates. If you were gonna go sony, a G model would be best (for price).
I have an LG795ft and it's beautiful. My best friend has a 700ift, and it's nice, and colors are a bit richer, but it's not as flat as the LG.
xtreme2k
3,078
i have the E200 also
using 1280x1024 at 75Hz
not great but i have no problems with it
the LG 795FT/G200 has 1600x1200 at 75Hz
if you want that resolution at 75, get those
kuk
2,925
I own both LGs and Sonys ... one sucky 15" from LG, and a nice Trinitron Multiscan 17" from Sony (too bad it maxes out at 1280x1024@60hz). I love sony stuff, except for a terrible CD-R that I had. LG has good tecnology, their 17" Flatron has some very nice controls, and an USB hub as an extra. The Samsung is a mistery. Never seen one up close.
Are there any 17 inchers that do 1280x1024 @ 80Hz or better ?
Imported
14,679
23
The Samsung 700NF can run at 1280x1024@85Hz(89Hz max) with a max of 1600x1200@75Hz(76Hz max).
LXi
7,987
<<I have an LG795ft and it's beautiful. My best friend has a 700ift, and it's nice, and colors are a bit richer, but it's not as flat as the LG. >>
The 700IFT is pure 100% flat, I dont know how you can get flatter than that.
kuk
2,925
As I said before, I have to go with one of these three: LG, Samsung or Sony.
LXi
7,987
You can just tell me beforehand.
They're all good monitors, so I'll get the one thats the cheapest.
kuk
2,925
Good monitors I know they are. But I wan't to know differences in picture quality, colors, controls, refresh rates, user opinions. That's what I'm lookin for here.
LXi
7,987
There are some major difference:
Sony:
Aperture grille(virtually flat), bright, clean image. Two damper wires across the screen so you'll see two thin lines.
LG:
Modified shadow mask(pure flat), I havent seen these, but from what I heard, they're very good, probably not as bright as Sony, but no thin lines at all.
Samsung:
Conventional shadow mask(pure flat), sharp text, clear image quality, very small dot pitch(0.20mm) not as bright as Sony, no thin lines.
