http://www.800.com/prod.asp?p=3067
Sony CD Car Stereo CDX1200
Free Installation Kit and Wiring Harness with Purchase!*
When you purchase this car stereo, our system will automatically select the appropriate installation kit and wiring harness for your vehicle and give you a $25 credit towards those parts.
*Credit up to $25.00. Some vehicles require parts that exceed this amount.
The CDX1200 CD receiver features Sony?s SSIR-EX? tuner, which employs advanced circuitry to ensure the best signal reception. You also get Best Tuning Memory (BTM), which selects radio stations by signal strength and assigns them to presets in numerical order according to their frequency value. Plus, 45-watts x 4-channel power output ensures easy integration with existing 4-speaker systems, and D-Bass makes any system sound better!
Main Features
45 Watts x 4 Channel Power Output is an amplifier capable of producing 180 watts of total output power, allowing you to drive up to 2 pair of speakers with ease.
Active Servo Control? a proprietary Sony technology for CD and MD players. This circuit monitors tracking and focus functions, among others, and actively adjusts those functions to compensate for real-time problems that may otherwise cause skipping or make a CD unplayable.
D-Bass? (Dynamic Bass) Sony's unique low frequency enhancement system which provides up to 15dB of gain to frequencies below 75Hz, without midrange coloration of interference.
SSIR-EX Tuner is an improved version of the original SSIR (Sony Super Interference Rejection) FM front end which offers better sensitivity, selectivity, capture ratio and stereo separation specifications.
Digital AM/FM Stereo Tuner processes FM and AM radio broadcasts digitally, locking in on the signal for less drift and reduced distortion. It also allows for simple storage of station frequencies in convenient presets.
Key Illumination refers to the back illumination for the buttons on the face of the head unit.
Single Preamp Output (1 pair) features one set of RCA-type jacks that allow you to use a standard RCA stereo patch cable to add an external 2-channel amplifier.
DIN Mount this unit conforms to the DIN standard, making it an easy fit in just about any modern automobile dashboard, greatly simplifying installation.
Audio Features
Single CD Random Track Play plays tracks on the disc in the unit in a random order.
Fader Control allows customized control between front and rear speakers.
PreAmp Fader Control provides signal level control between internal speaker level outputs and the line level outputs, allowing you precise control of a system mixing the internal amps and external amps.
8x Oversampling is a circuit that combines excellent phase linearity with superb suppression of digital noise, resulting in better and more natural sound and imaging.
1-Bit Digital-to-Analog Converter error free single bit Digital-to-Analog conversion significantly improves small signal linearity to provide pure reproduction of the original sound recorded on a compact disc.
Connections
Line Output Terminals provide additional flexibility in creating a high-quality mobile audio system by allowing connection to outboard amplifiers and signal processors with a line-level, un-amplified signal. The result is wider frequency response, wider dynamic range, and reduced noise.
Preamp Outputs 1 Pair
Additional Features
Volume Attenuator instantly mutes the volume at the touch of a button, then restores the original level with another touch. A great convenience when pulling up to the drive-through, or when your cell phone rings.
Shuffle Play allows the player to select tracks for playback entirely at random, adding a bit of variety to your listening.
Specifications
Mounting Type Din
Power Output (Watts x 4) 45
Station Presets 24
Here is the list of all the other onsale INDASH CD players
Main Features
Audio Features
Connections
Additional Features
Specifications
Mounting Type Din
Station Presets 24
