I currently have a 32in Sharp Aquos, and have been pushing it on this forums as a great large screen display. It has worked great for me and I love it. I wanted to get a bigger screen though.....SO... I am trying this Sony.
The Sony is a KDL-40s4100 and if it is the only thing that is plugged into my EVGA 8800 GTX the comp will not start. It will post then freeze after the post screen. I think it has something to do with the auto wide-full pixel settings, Becuase, when it post, it will be automatically go to full screen display mode, and then NOT move to full pixel settings. When both the sharp and Sony are plugged in the Sharp has to be the primary monitor on startup or the comp will not start; it will not if the sony is set to primary (once this is done the Sony looks great in 1080P). Once the comp is started though I can then set the sony as the primary monitor, but then I have to move the mouse right to left in order to access the secondary monitor (i want that to be the sharp) but the sharp is on the right hand side.
1. The Sony and Sharp are using HDMI inputs.
2. Does using the Analog PC input change anything for this problem?
Any suggestions? Thank you in advance.
