Sony 175CRX175E and Nero InCD Problems
Audax
22
Hi there,
I was just wondering if anyone has had trouble with their Sony burner (or any other burner for that matter) with Nero's UDF Packet wrting feature (InCD), ie. allows you to format a CD-RW and use it as a floppy. It fails to work on my system (win 98SE) and will freeze it until I eject the CD. Interestingly the same happens with EasyCD equivalent feature (DirectCD). I have the latest versions and patches which presumably detect and recognise my burner (both programs recognise the CD for normal burning). I'm not running both at the same time but I do have CloneCD installed! Any suggestions.
Also, Windows Explorer (or Powerdesk) takes ages to recognise the contents of both my CD's (a BCD 36x and the Sony Burner). I have to eject and mount the cd a couple of times for it to recognice it.
Thanks for any suggestions
Audax:confused:
wurmyhi
52
I've had problems with serveral pieces of software that let you "use your CD like a floppy," my own solution was to stop using it if it seemed buggy (Sony Extreme, Easy CD Creator - haven't tried the Nero one).
Audax
22
Thanks for the reply. That may be the best solution. I haven't heard of Sony Extreme though.
