ok guys, seems easy enough, but I have come up with a good method yet.
Someone gave me a soho sonicwall, which I thought would be very cool, but as far as I can tell it does not have dhcp enabled on the lan side. The guy that gave it to me does not know the IP of the router. According to sonicwall the ONLY way to admin this thing is via its web page on the internal ip addy. There is no reset buttons/switches that I can find (even on the inside).
So, I connected my lappy to the lan side and set the ip to 10.0.0.2/8 and proceeded with a nmap ping sweep, but found nothing. So then I did the same with 10.0.0.3/8 (incase the ip was .2), and nothing. So then I did the same with the 192.168.x.x addys and the 172.16-32.x.x addys... nothing...
So anyway, I'm getting annoyed. I'm starting to think the thing is not responding to pings (it is a firewall afterall), so I'm not sure how I'm gonna get its IP.
anyone have any ideas on how to get the ip or how to reset the d@mn thing to factory defaults?
