Something strange while running prime95
DragonFire
Quick system specs
MSI K8N NEO2 platinum using modded bios 1.36 but I have the problem with the offical 1.4
FX-55 @ 1.45-1.55V
Corsair 1GB 3200XLPT @ 3-3-3-8
I'v been having problems running at 11x270+, so Iv started to try to find out if its my ram or the cpu...
Anyways, right now Im running 10x270 @ 1.45vcore. MEM timings are at 3-3-3-8 using 2.65V
When I run prime95's torture test and pick either In-place large FFT or Blend I start to hear a very low high pitch sound as soon as the test starts.
I can't tell if its coming from the cpu, ram, or the motherboard. At the moment I believe its the ram, there are times during the test that it almost sounds like a HD seeking but no where near as loud as a real HD.
Iv also noticed the sound when I try to load/access a program after running a memory sucking program such as a game. Or, I run prime95 for a few mins and then bring restore mozilla, I can hear this sound as mozilla gets loaded back into memory.
If it is my ram I take it this is not normal? Is there something I can try to single out where the noise is coming from?
Chesebert
1,013
15
electronics can make sounds ...capacitor and inductors ..... mostly, correct me if I am wrong. nothing to worry really. some times they come in low hum, others are high pitch.
nealh
7,078
I get whine when running prime ..I think it is ok ....only program that does that..although some have reported a whine with scrolling there mouse on this mobo....
in fact some hear whine from the mobo from capacitors or donut looking things at idle..there are a couple threads at extremesystems about this
But I get in Prime95..when I hear I know I am still going just fine...
DragonFire
This is the first time I have ever exp such a thing. I'v also come to find that the higher I overclock the worse it is.
nealh
7,078
yea.. I thought it seemed strange but it is the only program I have had this haappen...and given that over the last week I have run Prime 95 for 100 hrs with no ill effects I am not worried
DragonFire
oh, well prime95 isnt the only cause for me. Super Pi causes it but not as bad. I also hear it for a split sec while my computer is starting up, it happens right as my screen flashs off from showing the pci devices to showing the XP loading screen...
nealh
7,078
oh yea I forgot super pi will do this as well...I will occasionally hear whine after the initial boot and if I open core center...
with the exception of the noted apps..the whine seems to be otherwise gone
Chesebert
1,013
15
probably pushing those caps and power fets pretty hard :) they like to whine when they are pushed hard...lol....sometimes could just be the heat generated .......
Loki726
228
Do you have a fan controller? Some boards come with fan controllers that can increase the speed of the fans and make more noise when the temp goes up.
RetailDirect
58
My A64 3000+ Winchester did this whining also in the beginning. I jacked the voltage as far as possible on my K8N and ran P95 large FFTs for a while and the sound has finally gone.... I guess its just from breaking in on the smaller process (90nm)
I was also worried but read somewhere that the sound should go away after a while. :)
flawlssdistortn
680
Yeah this is normal, probably you are hearing the MOSFETs. I know I hear em on my board, especially with the dual power system.
AnandThenMan
3,991
627
I've had this happen to me before. I traced it down to the HSF. It was resonating somehow. I removed it and re-installed it and the problem went away. This may not be your problem but it's worth a look.
