EVGA 1000 G2 would be fine too but it's no cheaper. EVGA 850W G2 is just $95 AR but I'm not sure if you want to downgrade from 1000W. It should be fine for your setup as long as you're not overvolting things much, but the 1300W unit is the way to go if you want to have as much room for OC as possible.
