Someone Please help . .. :(
8008S
Banned
Sep 17, 2000
611
Hey all,
ARGH!!! Internet connection sharin is a pain in the butt! I HAD wingate running fine, then i installed zonealarm on the host, now that won't work. I tried shuttingdown zone alarm and reinstalling the program and it STILL doesn't work :|. Then I tried useless win98 ICS, bah, don't get me started on that. What other choices do i have?! :(
My duron and my P2 can't crack unless I can get some sharing :( :(
MrAtheist
148
Maybe you can run Win2k :) It solves all problems... But honestly, I wouldn't know how to solve your problem other than formatting...
Good luck!
8008S
Banned
Sep 17, 2000
611
Well I did a little search on google (god bless google) and hopefully what i found will help...
JimMc
<< I wouldn't know how to solve your problem other than formatting... >>
Yeah, an ICS problem that requires formating. Thanks Mr DPC, you're very helpful.
Choralone
924
8008S have you tried Winproxy? I believe the trial version will allow a few machines to connect to yours for 30 days before timing out. At least it'll keep you other machines fed for a while if it gets around the problem you were having with WinGate after you ran ZoneAlarm. Get it at www.winproxy.com Hope this helps!
NT4Mike
You could try proxy+. It's what I have been using on my machines. It is free and does not expire either.
-Mike
divide by zero
1,025
Proxy+ looks interesting but it's free only for 3 users. Would that limit it to three cows? How many cows do you have feeding off of proxy+?
Michael
Elite member
Nov 19, 1999
5,435
234
I use NAT32. I have had good luck in getting all my computer (W98 and Linux) to share my connection and it is pretty flexible in port setting so you can run games behind it with a little tweaking.
Michael
