Somebody Please Help Molly !!
molly001
Wow -- I didn't think editing home videos created by burning from a VHS tape would be this hard!
Here is what I have: VHS tapes, which I then use (successfully) in combination with a Sony VRD-MC1 DVD recorder. It turns my old home VHS tapes into playable DVDs (playable on set-top DVD players, as well as Windows-aligned DVD software players).
Note: Roxio Easy Media Creator 7 Basic detects the accompanying audio as AC3, but that doesn't mean much to me. This version of Roxio cannot work with AC3, leading me to my trials below...
OK, great. This is where it gets tricky. When I use Windows Explorer to look at these created DVDs, it makes VOB files of the 'meat' of the recordings. I could tell I would need to edit these VOB files, so I did my homework.
A week later, and lots of shareware later (such as ChopperXP), I can chop these VOBs into smaller VOB files containing the shortened clips I actually would like to use.
Then come the 'put together' shareware which allows me to connect clips with text and transitions and make a continuous video of my smaller clips. That works OK -- that is, I can make a video from these clips, using software such as MPEG Wizard.
After that, it's been a nightmare. Getting my edited continuous clip into any useable form has been a disaster. I can convert it into an MPEG, but the MPEG will be unplayable, or the audio will be off track, or the video freezes up, etc. There is surely a better way.
Can you guys please recommend me to a software package that I can purchase which will successfully take my DVD video TS thingy, and allow me to chop, clip, cut, insert, edit, author, etc? I would really appreciate it!
