Some system tray icons hidden
KevDODOUBLEG
381
A few icons on the system tray, including AIM are hidden (they are set to always show in the properties, and there is no arrow to expand the tray). Any ideas?
Boobers
799
If you're using XP, try this:
Right click the gray area of the task bar, and choose properties.
Clear the check box that says "Hide inactice icons."
If you already have this set (as your posts suggests), then I'd try removing/reinstalling AIM, etc.
