What seams to be the problem.
Yes the PCI-e slot offers a max of 75W or 6.25A from the 12V rail. Are you looking to power some sort of card off the AGP slot?
I have found the full Intel spec for AGP.
http://members.datafast.net.au/dft0802/specs/agp30.pdf
Section 3.6 Page 77 covers the power distribution of the slot.
Browsing the spec reviles now power limits which suggest that all voltages supplied threw the slot are less then 1A. AGP cards where not demanding in power when AGP was first introduced. Those that needed more had additional power inputs as covered before. So if you plan to use the slot of anything other then a video card don't expect to pull more then a few milliamperes from it. If you trying to test a motherboard to see if the slot is supplying the proper amount of power your not going to get the slot to output any significant amount of current without a load. Chances are the current threw the AGP slot will be the same or similar to that of the PCI slots. basically AGP is a specialized PCI slot that has its own controller so it doesn't have to share the bridge the other slots are on offering fast data transfers.
