First I ordered it because I didn't want to wait for the nForce 2 boards to be in stock (little did I know it was 1 day), so how bad am I getting screwed on performance? Also I have PC 2100 memory so that's only 133 bus right?
I am also wondering what I should shoot for for a very modest safe kind of overclock? I run an XP 1700+ T-Bred A. Is running at a 166 bus a likely goal? I will not run an odd bus (only 133, or 166 as I have had data corruption issues before). If 166 is too lofty what multipliers would you try? Remember my chip is sacred to me (being poor) so I am looking to stay reasonably on the safe side. I assume you must be able to run the chip bus seperate from the memory bus....? Also what temps are safe for the chip. Bear in mind that I have only stock AMD cooling for at least a week or two. Anyone have any ideas about a cheap hs/f that is a good cooler? (I don't want to spend more than around $20)
