Some linear algebra homework help, please
Howard
47,986
11
Suppose that u and v are vectors in an inner product space V for which ||u|| = 3, ||v|| = 4, and <u,v> = 10. Find ||2u - 3v||.
I tried finding the angle between u and v so that I could find it geometrically, but no luck, since it wasn't a special angle.
Any ideas?
EDIT: Good point. Also, another matrices question down below.
TuxDave
10,571
I don't remember learning this in algebra.... :(
What does <u,v> = 10 mean again?
Howard
47,986
11
OK, maybe you can help with this one.
Let A be a 3 x 3 invertible matrix, and assume that 2A^2 = 3A^3. Find |-A^-1|
(I assume that's the determinant of the negative of the inverse)
TuxDave
10,571
I think you need to add the word 'linear' in front of 'algebra' in your topic title.
fs5
11,774
been so long, sorry can't help. when you stop doing linear algebra for 3 years it kinda leaves you.
TuxDave
10,571
-3/2?
eigen
4,000
-3/2
TuxDave
10,571
Any ideas?
Why can't you find it geometrically again? You have the magnitude and you have the dot product, so can't you find the angle really fast? And then with the angle, you can find the magnitude of 2u-3v pretty fast using geometry or trig.
maziwanka
10,415
hey dude. if you assume u={x1,y1} and v={x2,y2} you can figure out the answers to the first question. if you need more help ill post my answer
edit: i think i got sqrt(60) for the first problem.
TuxDave
10,571
-3/2
Beat ya to it!
RaynorWolfcastle
8,968
16
-3/2?
yeah that would be my guess. For the other one are you using the standard inner product or is it some general inner product? I haven't looked at this stuff for awwhile but IIRC the inner product rules that apply are ||u|| = <u,u> and <u,v>=<v,u>. I'll have to think about it for a solution though
oh yeah and
||2u-3v|| = <2u-3v,2u-3v> which I think you were allowed to distribute as
<2u,2u> + <2u,-3v> + <-3v,2u> + <-3v,-3v>
I'm not sure about this last step, but I also think you can pull constants out of inner products by definition
so that would leave you with
4<u,u> - 12<u,v> +9<v,v> = 4*3 -12*10 + 9*4 = 12-120+36 = -72
Not positive about this, though
maziwanka
10,415
i thought an invertible matrix has 0 determinant.
edit: hahahaha, its the opposite thing: if the matrix is singular, its determinant is 0.
eigen
4,000
-3/2
Beat ya to it!
A is non-singular so you can "cancel" the A's leaving 2=3A => 1=3/2A.Then since the Det(A^-1) = 1/A
you get the answer.
TuxDave
10,571
I thought they have non-zero determinants. It's been 4 years so I may be wrong.
Howard
47,986
11
I get ||(2x1 - 3x2, 2x2 - 3y2)||. Is that what I'm supposed to get? If so, I can't find the relationship to <u,v> or the norms of u and v. <u,v> = x1x2 + y2y2, right? And ||u|| = (x1^2 + y1^2)^/2, correct?
RaynorWolfcastle
8,968
16
tentative solution for the other problem in my other post. You'll have to verify the properties I use though, because it's been awhile since I've looked at it
