Some help re: Asrock extreme 4
Gepidae
155
Alright so I have i5-2500k, extreme 4, and the CM hyper 212 plus in a push/pull config. I do have the latest 1.70 bios. I tried OCing w a multi of 48x and I ran intelburn test 3 runs on max. with 8 threads and it passes just fine. Issue is when I turn off the computer and try to turn it back on again it just doesnt want to go into windows OR bios, its just a black screen. Can someone please help with this issue? Thanks
Gepidae
155
Alright update, Im using STOCK settings w no OC and after shutting down it wont boot into windows without a cmos reset. Does anyone know whats going on?
de8212
4,021
Are the fans coming on when you see the black screen? I have pretty much the same build and running 4.5 with no issues (other than double boot) but I haven't updated to 1.7.
How about error code? Is there one listed on the boards display?
Gepidae
155
Yes the fans appear to be spinning. Sometimes there is no error code and sometimes I get a 60. Someone suggested it might've been PSU on another forum but I dont think that explains why a clear CMOS fixes the boot issue.
If it helps any I am using CM silent pro 600 w PSU.
