Some confusion about how my fan is wired
The Pentium Guy
4,327
So I received my Panaflo L1A 80mm just now in the mail.....
There's a 3-pin end going to the fan itself, and on the other side is a 2-pin connector (there are only 2 wires in this fan).
Any tips on what to do?
Thanks,
-The Pentium Guy
RaiderJ
7,582
Maybe it's set up to hook into a mobo fan header... but separate wires to allow for easy adjustment of 12V or 7.5V operation?
The Pentium Guy
4,327
Mobo header is 3 pin as well.
Anyhow, I fixed the problem. For those of you who have this problem, here's the solution:
The controller that goes to the fan is a 3-pin, but the controller that goes out is a 2-pin.
The shape of the 2-pin plug looks like this:
|UU|
EDIT: Hit the QUOTE button to see the proper formatting
Where the "U" represents a female connector.
3 Pin male connectors (on the motherboard) look like this:
|III|
Where the "I" represents a male connector.
All you have to do is take the 2-pin female connector (from the fan) and "eat" off one side:
|UU|
Now when you plug it in, leave the right-most pin empty.
For those of you who can't see the ASCII art properly, just hit the "Quote" button, and it'll give you the proper spacing.
-The Pentium Guy
