some bluetooth usb dongle help please!
zimu
6,209
hey guys,
so i'm finally jumping on the bluetooth wagon!
although a little confused as to v1.1 versus v1.2, and what "speed" I should go for.
i'm looking around ebay as a reference point, and see dongles that have speeds from 768kbit to 4mbit-- would the 4mbit ones be compatible with my sonyericsson?
essentially looking at 3 options:
option 1
option 2
option 3
what are your $0.02?
Cheers!
zimu
6,209
Originally posted by: Mo0o
dongle... nyuk nyuk nyuk
lol, i saw the same response in another bluetooth "dongle" thread, i think it was you!
tm37
12,436
Remeber you are not buying a dongle as much as you are the drivers.
Look at some issues with the phone and what dongles pe3ople are using.
Although there is a BT standard some dongles do not work with certain devices.
