Yep im using afterburner. I have it at 20% not sure if i should put it back to zero. you sure those are the correct 2d speeds?
seesm like mine is 450/1250
How many monitors are you running?
Single, did you disable powerplay in afterburner?How many monitors are you running?
The problem with afterburner is it disables powerplay once you activate unofficial overclocking or overvolting. The best way around it is to:Single, did you disable powerplay in afterburner?
The Shaman Cooler was off eBay, some guy was selling it cause it takes up 4 slots and Multi-GPU capability is limited.Options: Resolution: 1920 x 1200; DirectX: DirectX 11; Quality: Very High; Antialiasing: MSAA 4X; Texture filtering: AF 16X; Advanced PhysX: Disabled; Tesselation: Enabled; DOF: Disabled
* Total Frames: 3494, Total Time: 59.87474 sec
* Average Framerate: 58.46
* Max. Framerate: 236.57 (Frame: 3090)
* Min. Framerate: 10.99 (Frame: 1631)
Options: Resolution: 1920 x 1200; DirectX: DirectX 11; Quality: Very High; Antialiasing: MSAA 4X; Texture filtering: AF 16X; Advanced PhysX: Disabled; Tesselation: Enabled; DOF: Enabled
* Total Frames: 1330, Total Time: 59.68909 sec
* Average Framerate: 22.38
* Max. Framerate: 50.49 (Frame: 14)
* Min. Framerate: 8.07 (Frame: 719)
Nice scores, what card(s) is that at what speed/config?
Thanks for the benches.
You sure Crossifire is on? Your average seems a bit on the low side wouldn't you say?These are dual 6950s that I flashed to 6970s. I also bumped the core up to 880 but left the memory alone.
Might have to pick up a couple shamans as I have an asrock board. The problem is I don't have one of those extended crossfire connectors and would have to buy that as well I think.
What version of Afterburner are you using? The new beta 7 still has Powe Play even if you enable unofficial overclocking!Single, did you disable powerplay in afterburner?
