Some advice on what monitor to purchase please.
handyman_opus
So, I live in Sweden and I've got limited choices of what to buy. I have narrowed my choices down to a few in my price range.
Some LED backlight monitors -
1- BEN Q 24
2- Ben Q 21.5
3- LG 22
4- Acer 22
5ms response time -
5- Acer 22
6- Acer 23
7- Acer 22
2ms response time -
8- LG 22
9- Phillips 22
10- Acer 24
One that has caught my eye that is on sale for 3 more days is Ben Q 24.
Now this is the only one I can find specs on and I realize it's tn film. I'm assuming the others are as well, but it's not that much of a bother. I'd just like the best monitor for the price.
Any help is appreciated, and what I'm most concerned with is if LED will make a difference as well as the response times. If anyone can find info on the others i've posted that would be amazing. Thanks in advance.
Well, Sony will always pown the rest of the ofus..
can you please say something logical that actually pertains directly to the question? you clearly only post just because you are bored or you want to increase your post count. either way its so tiring seeing you say such useless and random nonsense in almost every thread.
Wait and get LED LCD , if you can cope with what you have now. Give her 2 months and you eget good price on a 24 inch 120hz,,,, thx
It kinda depends on what you're doing with it. That Acer is the same price as the Ben Q so I don't think you should feel pressured by a sale. I'd suggest going with one of the 24" ones regardless. Then again the 23" Acer is a few hundred cheaper but 5ms response time. Unless you absolutely need the 2ms time then the 23" Acer may be a good choice.
Well, as you can see there are some LED I linked to.. those are not going to change prices in 2 months over here.
I'll be using it mostly for gaming. Will the 23" Acer be much different from a 24" BenQ on size? They are the same price but also I haven't had much luck with Acer brand in the past. Their products seem cheap, but on the other hand I've never had a BenQ product. Thanks for the reply
