solvent for thermal compound?
uglytobone
Is any household stuff ok to use? Alcohol, fingernail polish remover, paint thinner, just a clean dry cloth?
Thanks.
ch33zw1z
39,767
20,339
just use isopropyl alcohol and some qtips, or lint free cloths. alcohol wipes work good too.
nova2
982
as long as it wont leave any residue (alcohol for sure wont) on the heatsink it doesn't really matter
DrMrLordX
22,953
13,043
91% ipa is easier to get than 99%, and either one should be fine. some folks complain that it leaves a residue but it's not a big deal (I don't think).
91% ipa + coffee filters ftw
MDE
13,199
Rubbing alcohol. You can go as low as 70%, but it'll take longer to evaporate. 91% is relatively easy to find (I got mine at CVS for about a buck).
