Gigabyte GA-P35-DS3L Updated BIOS from F5 to F9 with @BIOS (system wasn't seeing my USB keyboard) After the update, the CPU fan seems to be running at 100% even though the "smart fan" BIOS option is enabled.
But all was well until I did the BIOS upgrade. The chances that the fan or a temp sensor suddenly fell off a cliff at the exact moment I did the BIOS are... not good.
