Patrick Wolf
I want to replace those white squareish things on my 9800 GX2's heatsink. I believe it's thermal tape.
That's not my 9800 GX2. Mine's not so "pretty".
Would arctic silver ceramique work, or do I really need tape to fill the gap? Like this stuff: http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=Sekisui+thermal+tape
UPDATE: The 0.5mm EK Thermal Pads worked, but I can still see some tiny gappage between a couple of the pads & VRAM. It's working fine, but I'm going to order these 1mm & 0.5mm pads and use the 1mm.
http://www.performance-pcs.com/catal...ducts_id=25822
Other than that, temps are much better and it no longer crashes from overheating! EVGA Precision shows a 5 degree difference between GPU's, so maybe I didn't use enough (or too much) MX-2. Although GPU-Z shows them as being relatively the same.
UPDATE 2: Well damn. That didn't work. The 1mm pads were too thick! The core couldn't make good contact with the heatsink. So I replaced them with the 0.5mm Koolance pads and all was good again. I put a little pad on the SLI bridge controller as well since the paste wasn't making full contact.
FYI: The 0.5mm EK and Koolance pad looked the same except the Koolance was more tacky and seemed more fragile making it more difficult to work with. The 1mm pad was nice though. Tacky, but only had one protective film to remove.
