- Aug 25, 2001
- 56,587
- 10,227
- 126
I built some AMD Athlon II quad-cores last year, intending to sell them, based on parts and combo deals from Microcenter (free or nearly-free mobo with purchase of AMD X4 630 and 640 chips).
Anyways, I finally sold one of them at the beginning of this year, along with a HD4850 graphics card.
I had two left, one with an Asus NV-chipset board (6150 maybe), and one with a (I think, Biostar?) 760G mobo, both micro-atx, both DDR2 (paid through the nose for 4GB of DDR2 back then, it was when it was at $100).
I was using a case + PSU combo from ewiz, with a "400W" (25C) PSU.
For the machine with the NV chipset, that I upgraded with another HD4850, I tested it with five minutes of OCCT PSU test, and nothing smoked or shut down. I was however afraid to test it any longer.
For the machine with the 760G, I dug it out tonight to run some Distributed Computing on it. I set it up at my third desk, with a newly-unwrapped 25" Hannspree LCD.
When I hooked it up and turned it on, it wouldn't POST. So I opened it up, and re-seated the RAM. That seemed to do the trick.
I am using a USB Dell keyboard, and generic ewiz USB mouse. For video output, I'm using a DVI-to-HDMI converter from AMD (out of a HD4850 box), and an HDMI cable to an HDMI port on the monitor.
I have a "Tenda" wifi N150 adaptor, and a "High-power" wifi G adaptor, as my options to connect to the internet.
Once I had the machine booted (Windows 7 HP 64-bit), I plugged in the Tenda adaptor, and it automagically installed the drivers.
It seemed to work for a little while, but then it gave me the yellow warning icon over the network icon, no internet access.
I did the diagnostics, and it said to investigate the router. Only thing is, I also had a laptop running internet radio streams over the same wireless router, and it never missed a beat.
I tried various things, and to make a longer story shorter, sometimes the network icon would hang, I wouldn't be able to access the Network and Sharing Center thing, and when I tried to shut down and reset, Windows would hang at the Shutdown screen. So I hit the reset button.
At one point, with the Tenda adaptor plugged into the front-panel USB, the BIOS POST hung at "Enumerating USB devices". So I thought that perhaps the front-panel ports weren't supplying enough power, so I plugged it into the back. I had to re-arrange the keyboard/mouse plugs too.
At some point, the keyboard and mouse would stop working.
Even further along, with nothing plugged into a USB port, the computer stopped booting altogether.
Thinking it was a failing PSU that was dying due to the load on the +5v or +5vSB, I swapped in a nice OEM Enhance 500W unit.
After swapping in the new PSU, it booted right up again, and I managed to get online briefly with the Tenda adaptor, but it was still hanging up at some random point after showing that Win7 had internet access.
And that's where I left it. Not with the Tenda adaptor, not with the High-Power G adaptor, it won't stay online for more than a few minutes. Very frustrating.
My last-ditch effort, would be to connect up one of my routers with DD-WRT, as a WDS node, or client-mode wireless.
But I'm wondering if there is a potential mobo issue, especially with the USB ports.
Or maybe I just need to do a fresh install of Windows 7, perhaps something has gone wonky?
Or perhaps the Crucial Ballistix DDR2 has gone bad? It's not the 2.1v Ballistix that was famous for failing, it's newer stuff at standard timings and voltages.
