(SOLVED)Need Help unlocking My HD 6950 2GB
Durvelle27
4,102
I was thinking about trying to unlock the shaders on my Sapphire HD 6950 2GB. i want to know how can i do this. Thx for any help received :)
this is the card i ordered
SAPPHIRE 100312-3L Radeon HD 6950 2GB 256-bit GDDR...
Keep getting this error
RussianSensation
19,458
765
thilanliyan
12,062
2,275
Are you sure that card is flashable? Not all 6950s, especially the non-reference ones are flashable.
thilanliyan
12,062
2,275
I personally advise against unlocking it. You probably void your warranty when you do it too. You're better off just overclocking. You get a larger performance benefit from higher clocks than you would with unlocking shaders from what I have read.
RussianSensation
19,458
765
Even the clock speeds didn't change? You sure you flashed using the correct BIOS switch? It won't let you flash if you didn't move the BIOS switch since one of them is a read only bios.
Here I uploaded my unlocked shader PowerColor PCS+ 6950 BIOS 1536 shaders, 880mhz GPU clocks:
http://www.2shared.com/file/8p5rg9br/powercolor_pcs_6950_standard_b.html
But it'll have that card's fan profile (so set up a custom one in MSI afterburner if this is too loud for you).
Durvelle27
4,102
i currently have the switch set to the one position i think
RussianSensation
19,458
765
Tried the flash on both BIOS switch 1 and 2 positions?
If RBE mod or an HD6950 1536 Shader BIOS mod didn't work, your card can't be unlocked.
thilanliyan
12,062
2,275
I use afterburner to OC and Unigine Heaven/3DMark11 as a stability tester for quick testing, and then gaming sessions for long term testing.
p_monks33
1,292
Sorry, I see you solved it already, I didnt catch this thread until today, That card is built upon a 6870 PCB it looks like. The same goes for the HIS ICEQ versions and the center fan HIS 6950's . I found this out the hard way after I got water blocks for 6950's and they turned out to be 6870 PCB's. IDK why companies did this?
