[SOLVED] Metal Gear Solid V Phantom Pain FPS Drops with CPU and GPU at 50%
Inbox
14
[SOLVED] The problem was the Windowed Mode was set to Borderless Fullscreen instead of Fullscreen. Thanks alcoholbob.
Good evening.
Recently I started playing MGSV Phantom Pain (1080p, all settings maxed out), but the problem is that I'm experiencing FPS losses, even when the CPU and GPU are at 50% at most.
If there is no bottleneck on the GPU and CPU, why are the constant FPS drops happening? Can it be because of the lack of vram (as each one of the GTX680 only has 2GB of NVRAM)? Even GTA V runs great with only 4GB (2+2GB) of NVRAM.
Is anyone experiencing similar issues?
Regards.
My PC Specs:
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i7 3930K @ 4.50GHz
Sandy Bridge-E 32nm Technology
RAM
16,0GB DDR3 @ 772MHz (11-11-11-28)
Motherboard
ASUSTeK COMPUTER INC. RAMPAGE IV FORMULA (LGA2011)
Graphics
W2486 (1920x1080@60Hz)
2047MB NVIDIA GeForce GTX 680 (NVIDIA)
ForceWare version: 355.82
SLI Enabled
Storage
238GB OCZ-VERTEX4 (SSD)
931GB SAMSUNG HD103SJ (SATA)
931GB SAMSUNG HD103SJ SCSI Disk Device (SATA)
2328GB Western Digital WDC WD25EZRX-00MMMB0 SCSI Disk Device (SATA)
1863GB Seagate ST2000DM 001-9YN164 USB Device (USB (SATA))
139GB Western Digital WDC WD15 00ADFD-00NLR1 USB Device (USB (SATA))
Optical Drives
ASUS BW-16D1HT
Audio
USB PnP Sound Device
boozzer
1,549
18
that is not 4gb of vram that is 2gb of vram. that is not how sli or cf works. your 2gb vram is probably causing it, my best guess. it is also why 970 3.5gb gives really bad min fps in certain games.
Inbox
14
Yup I know, but even so I thought FPS losses every 5 seconds were not normal, as even in GTA V maxed out, (with the suggested limits disabled) I don't experience such drops, and I've 60FPS most of the time.
Regards.
Inbox
14
Make sure you are running in fullscreen mode and not borderless fullscreen.
Lol alcoholbob thank you so much that was the problem :cool:
I thought the game was running on fullscreen, when it wasn't. I only noticed that it was not when I was analyzing several screenshots I took just to remeber what settings to tweak and so on, and the first option was set to borderless fullscreen.
As soon as I changed it, the game is running at 60fps rock solid everything maxed out.
Regards.
alcoholbob
6,390
469
Yep this is why I'm selling my Titan Xs and going with Freesync + Fury X. A lot of games in fact don't even have a true fullscreen mode and only have a borderless/full screen windowed mode, which completely messes up alternate frame rendering frame pacing and makes 80 fps look like 20fps.
n0x1ous
2,574
252
Is there something freesync + fury would give you that couldnt get with your titan X's + gsync? or just single titan X + gsync?
96Firebird
5,747
342
Peter @ Nixeus said:
FreeSync at this time does not work when games are in "Windowless Border" or "Window Mode"
Source
Not gonna help you.
alcoholbob
6,390
469
The only 4k gsync monitor is a 28" TN and that's been out almost 2 years. There are over half a dozen 4K IPS Freesync monitors > 30" alone out today and many many more announced. Monitors can take over a year from announcement to release and we haven't heard any rumors of other 4k gsync displays. Likely they won't be available until Pascal is out.
I don't want to be stuck with GPUs that are incapable of adaptive sync and also are not fast enough to maintain 60fps necessary to sync to a monitor. People already have guides how to hack Freesync monitor EDID to get Freesync coverage down from 40Hz to 31Hz.
Basically, Nvidia does not provide the performance or the features I'm looking for, so I'm going AMD.
alcoholbob
6,390
469
Source
Not gonna help you.
Well we'll see. CF performance is also quite a bit better than SLI so two Fury Xs with Freesync should give a significantly more consistent performance than SLI Titan X + Vsync when Freesync is working, and when it's not it should provide comparable performance at 4k anyway.
40fps is much easier to aim for with Fury X CF than 60fps with Titan X SLI. Other than a few Gameworks games a Titan X isn't usually 50%+ faster than a Fury X, usually it's more like 15%.
