Hi folks - want to thank everyone for their help. I think I have this beast beat now. If you are interested, please have a peek at my latest post for an update.
Hello everyone:
I have been asking some piecemeal questions to try to get a bit more speed out of my rig, but in my fiddling I have found I have some stability issues and thought I would make a more compressive post to see if anyone can help me with the fine tuning.
The issues:
- random crashes while computer at idle: computer freezes or reboots -- I am not on the computer when this happens, so I cannot comment on exactly what happens at freeze
- BSOD after 3 to 4 hours of Prime95
Toubleshooting already done:
- Full Mallware/Anti-virus/Rootkit scans with MS Security Essentials and AVG Anti Virus 2013
- Minor bios tweaks do no appear to change much:
-- dropped DDR2 OverVoltage Control to +0.35V (was maybe less stable)
-- seems to run fine at "full stock/default" settings (though I haven't done any long stress runs)
System:
C2D e7500 @ 3.93
Gigabyte GA-P35-DS4 (v.2.0)
6GB PC 800 Patriot @ 859
Asus 7870 (stock)
Corsair HX620 psu
Thermaltake Water 2.0 Performer (cooler)
BIOS:
Robust Graphics Booster___________ [Auto]
CPU Clock Ratio ____________ [11 X]
Fine Clock Ratio ____________[N/A]
CPU Host Clock Control_ [Enabled]
CPU Host Frequency (MHz)__________ [358]
PCI Express Frequency (Mhz)_______ [100]
C.I.A. 2__________________________ [Disabled]
System Memory Multiplier (SPD)____ [2.40]
Memory Frequency__________________ 800 859
DRAM Timing Selectable_______ SPD __ [Auto]
Performance Enhance = [Standard]
CAS Latency Time________________ 5
Dram RAS# to CAS# Delay_________ 5
Dram RAS# Precharge Delay_______ 5
Precharge Delay (tRAS)__________ 16
ACT to ACT Delay (tRRD)_________ 3
Rank Write to READ Delay________ 3
Write to Precharge Delay_________ 6
Refresh to ACT Delay______________ 52
Read to Precharge Delay__________ 3
Static tRead Value_______________ 7
Static tRead Phase Adjust________ 0 [Auto]
System Voltage Control____ [Manual]
DDR2 OverVoltage Control__ [+0.40V]
PCI-E OverVoltage Control_ [Normal]
FSB OverVoltage Control___ [+0.15V]
(G)MCH OverVoltage Control [+0.125V]
Loadline Calibration______ [Enable]
CPU Voltage Control_______ [1.36875V]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Enabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Enabled]
Virtualization Technology................: [Enabled] Enabled if you use Vmware/Virtual PC
Integrated Peripherals
Legacy USB Storage Detect___________________[Enabled]
Temp readings (averages of Core Temp, HWMonitor)
CPU: Max 56C
System: Max 60C
Questions:
1] Any idea to the likely cause of instability/crashes?
2] What settings should I consider adjusting to improve stability but at the same time maintaining a similar OC level?
3] It has been suggested that +0.40 (Base of 1.8V + 0.40 = 2.2V) is too high for DDR2 Ram (thanks Idontcare very helpful responses) is this the case in all instances: I dont remember 100% but I know the Patriot sticks I have need a bit more volts than normal.
4] How are my FSB and (G)MCH (is this Northbridge?) levels? Could these be the problem?
5] And the question I don't really want to hear the answer to, am I just asking too much of this set-up?
Any other feedback would be appreciated.
Thank you.
Hello everyone:
The issues:
System:
C2D e7500 @ 3.93
Asus 7870 (stock)
Corsair HX620 psu
BIOS:
CPU: Max 56C
System: Max 60C
Questions:
Thank you.
