- Feb 4, 2003
- 35
- 0
- 61
The monitor once it would go to sleep was very difficult to wake up. The light on the monitor would stay yellow, and never turn blue. You would have to power cycle the monitor. The monitor was connected to the computer built in video and dvi port.
Solution was to change settings on the monitor in the menu.
Menu> Source Control
Auto-Switch Source change this to off, default is on
It seems like the monitor wouldn't look at it's DVI port to wake up. I was going to use a dvi>hdmi cable to connect the computer the the monitor, but this worked.
