Solved - help, Need Power supply for Tablet
ciproxr
I got this yarvik model TAB411, does not look like they are sold in the US.
The adapter is made to work in greece where the electricity is much higher.
Input 100-240v - 50/60Hz max 0.6A
Output: 5V 2.5A
Do i just need to find an adapter that works in the US that outputs 5v 2.5a like this one:
http://www.powerpayless.com/ac-dc-5...ink-di-624-di624-router.html?___store=default
anyone know if radio shack or bestbuy has adapters ? any advice ?
You also have to make sure the positive and negative are in the same place (center, outer ring). Amazon has lots of these listed by 3rd party sellers.
