How can I get the cpu fan to increase/decrease fan speed based on the temperature of the cpu? :biggrin::biggrin:😕
I found a freeware program called Speedfan...this works quite well.😎
If your CPU fan is plugged in to the CPU Fan header on the motherboard and you do not have the fan settings in the BIOS configured to always be a specific speed, then it will automatically speed up and slow down as needed.
