Hi everyone,
Since the previous thread about the noise problem become very long, I decide to post the solutions to the noise problem of the IBM T40 here. Credit for the solutions goto me, OldSpooky, lothix, Kangaroo802, caltrinity, nicowju, and brandonl. I also post this solutions on the IBM forum as well. Anyway, there are two prominent noise source on the T40 and we are talking about static hissing or buzzing noise. The first is the GPU and the second I believe is the CPU power/charging system (which can be fixed by changing the AC Adapter). To reduce the noise (or eliminate it for some people), try the following step.
1) GPU Noise
-> Go to display setting and choose Advanced.
-> Select troubleshooting tab.
-> Reduce the hardware acceleration by a notch.
This will reduce the noise from the GPU when viewing flash or animated GIF or move the mouse over a link by 80-90%. And the good thing is that the GPU power is more or less the same. I tested this only on the 3DM2k1SE and get more or less the same scores (about 4980).
2) CPU power/charging system noise (source of the noise in this case is pure guess from me but the solution works)
-> You need to call IBM and request a replacement AC Adapter and power cord.
-> The default AC Adapter that shipped with the T40 or T40p is FRU 08K8205 either rev00, rev01, or rev02. The rev02 is the best for this FRU AC Adapter but still produce the noise.
-> When you speak to an IBM TS, tell him or her that you want a replacement AC Adapter to try to see if it help reduce/eliminate the noise or not.
-> IBM have a new FRU part for the field replacement of the default AC Adapter. It is 02K6753. IBM TS should be able to pull this FRU up right away since it is on their system and designated specially as a replacement part for 72W AC Adapter for T40 (or T40p).
Please note that combining these two solutions, the noise is still exist but is lower considerably (by at least 70-80% in my case) and barely audible under the "Always On" power setting or heavy cpu load only. You should change the power setting in Windows to be "laptop/portable" or "Wod processing/e-mail" to eliminate the noise completely under normal cpu load condition (i.e., you will not hear the noise at all under you stress the cpu). If you choose to use "Always On" power setting, you will still hear the noise by it is considerably less than using the old AC Adapter and without reducing the GPU setting.
With the solutions applied and use "Laptop/Portable" power setting, I cannot hear any noise under normal work load (well, except that static charging noise from the AC connection which is very very low). Under the "Always On" setting, the noise is audible within the range of 2-4 inches (compare to 6-12 inches before applied the solutions). Try this and let me know whether it help
Mocca
1) GPU Noise
Mocca
