Anyone know of a good solution that would enable to get at leats 12 hours of battery life on a PC (probably would be a laptop). Basically this is for hospital PCs that are on carts and get moved around from room to room. They're wanting a solution where at the end of the shift the nurse can swap out the battery and let the other charge. So there would be 2 batteries per cart. Would be preferable if the PC does not need to be shut down for the switch over.
The laptops take 19.5 volts which is a weird number, so something like a boat battery or similar would not work (and would probably not be safe anyway), almost need something that will either produce 120V AC so the adapter plugs straight in, or something where the voltage can be set.
I was looking on batterygeek.net and there's interesting stuff there.
We're also trying to stay away from any chemical based battery such as lead acid, so is there even anything out there that could work? 12 hours is long expectation but that's what they want.
Edit: Also what does watt hours mean? Is it that it can produce 1 watt for that time? So 200 watt hours would mean it can last for 200 hours if it's powering a 1 watt item? So if I want to power 2 watts, then I just divide?
