I ordered a Thermaltake 60MM
Statistics: 60x60x25, 31 CFM @ 4550 rpm, 28 dBA, 1.8w .17 Amp, 12v DC, 3-pin connector.
I found the 31cfm seems to be a good compromise between the YS-tech 27cfm and the 37cfm delta. I don't know if I believe it is this quiet, but I will find out Thursday. I am using the YS-tech 27cfm now, and while it is way more quiet than a delta, at 36 dBA it isn't exactly silent. I also ordered two 80mm low speed 31cfm 28 dBA fans for the case, the ones I have now are generic and noisy. I modified my two blowholes from a tight circular drilled pattern to open holes with nice chrome grills. It made a huge difference, case temps 28c and cpu temp 35c after 2 hours of Mech 4. Waiting on a A1 Electronics 400-watt so I can crank the cpu up to 1500+. After switching to a Geforce Pro and DDR board from Sdram and a V5 which ran off a second power supply, my old power supply just isn't strong enough. I'll post temps with the 31cfm fan when it gets here.
