- Aug 14, 2000
- 22,485
- 2,416
- 126
I'm posting this to help future people doing google searches as when I tried there were no results to help me, so I solved it myself.
Problem
The sorting order of songs within albums is wrong on the iPod and doesn't match iTunes' correct order. Specifically, purchased songs are all in a cluster at the start or back of the album, while ripped songs are correct.
Solution
The iPod seems to more aggressively use the Album Artist tag than iTunes does:
So either make sure the field is correct for the whole album, or just clear it. I clear it which also saves a tiny bit of disk space.
Problem
Solution
