I'm having some trouble connecting a new computer build with roadrunner cable internet service. Here are the specs on the computer (it's not a gaming rig, just a stable/cheap home office tower for a friend)
W2K Pro
A7N8X Deluxe (BIOS rev. 1002)
nForce 1.16 drivers from Asus website
Athlon XP 1800+
2 sticks 256MB Crucial PC 2700
G4 MX440 SE
Maxtor ATA-133 40GB 7200RPM
Lite-On 48x 24x 48x CD-RW
Antec SLK2600AMB w/ 300W Antec power supply
PCI 56k Modem (dial-up only in his area right now, but some broadband within the next 1-2 years)
Anyway, both the onboard 3Com and the Nforce Lan connections will not renew their IP addresses. The home network I'm using currently has a Linksys BEFSX41 router with a Toshiba PCX2200 cable modem (courtesy of RR). Both the 3Com and the nForce LANs have been configured for DHCP. (they have the same settings as the other machine on the network also running W2K Pro).
When I try to renew using ipconfig I receive a 'DHCP server unreachable' message. I have tried to renew the IP address with ipconfig under the following conditions:
1) Connected each RJ45 port to the router
2) Disconnected the cable modem from the router and connected each RJ45 port directly to the cable modem
3) Disabled each port in the BIOS and tried 1) and 2) with only one functional RJ45 port.
The same problem exists regardless of the number of functional RJ45 ports. When connected the link light for either RJ45 port is green and flickering like some kind of data transfer is happening.
The RoadRunner software setup gives the error message 'Your NIC is configured with DHCP but it cannot renew an IP address' or 'Both are configured with DHCP but neither can renew an IP address'
Any suggestions would be greatly appreciated...I have two days until I said I would deliver the puter.
W2K Pro
Athlon XP 1800+
G4 MX440 SE
