SOLTEK SL-75DRV2 and swiftech 462
Maverick762
13
Will my swifty work with the soltek? I know it's a big mother, and I heard that the board has problems with the alpha. Is there any problems here?
o1die
4,785
If you read the info on their website, the 462 is designed to fit all socket a boards that have the 4 open holes around the socket area. You have to remove the mobo for installation, and decide if you want to glue the plastic retainers that go into the 4 holes in place, to permit future removal of the heatsink without having to remove the motherboard again. I would read their installation instructions carefully before buying. You may want to go with the mcx 370 instead. I use the thermalright sk6, and my cpu temps are in the mid 40's with an old desktop case with poor venting and only one case fan in front.
cigar
66
i use the 462 on my soltek and the top left corner had to be rounded out for the the thing to fit past the lone capictor in that corner. used a dremel and about 10 min of work, temp at full load running prime torture is 95 degrees farinheit. best cooler on the market!
