The Internal
I have had one head ache after another with my new computer, so I was trying to think of anything I could do to get it stable. Oddly enough, my high performance Crucial Ballisitx RAM doesn't want to run at DDR400 on my Soltek QBIC EQ3801, a SFF recommended by anandtech (the system fails the MS RAM diagnostic tests when I leave the RAM settings on AUTO and Windows XP crashes like mad. I underclocked my RAM, and suddenly my system hasn't crashed and it passed the RAM test... wtf?!?!) Sadly, my system will not run stable unless I underclock my RAM to DDR333. Has anyone else encountered this problem? This is, admittedly, also on the same system that has had the physical MAC address change 6 or so times between two different numbers, hangs at least every other time when trying to detect my SATA channels, and doesn't want to boot from a SATA Maxtor Maxline III 300 GB. Am I overlooking something in the BIOS or what? Why can't I stably run my system at the specs it was designed for? Should I just RMA the proc and the barebone system? I'm running the latest BIOS revision, and have all the current drivers. Windows XP Pro, service pack 2.
