Soltek Problems
Junglesleeve
I recently put together my new computer and after installing all the necessary hardware, when I hit the power button the computer turns on for a fraction of a second then right before it shuts off I receive an error code of just "F" on the debug screen. Can someone help me?
Originally posted by: ChineseDemocracyGNR
List your full system specs.
I would also edit the topic title to be a little more descriptive of your problem. 😉
Yeah you should. I don't even know what board you're talking about.
Check if your PSU is good (it could be failing right after you boot it), I don't think its a video card problem or you woudln't be seeing anything. It could be a RAM problem as well.
Clear the CMOS and see if that helps. And then try for a bios update if it works.
-The Pentium Guy
