I just replaced my ex's computer with the K8AN2-GR mobo and an Athlon 64 2800+. I added 512 pc 3200, and a Geforce 5200. The only original parts in the computer are her HDD (IDE, not SATA) and dvd and cd burner. When I turn on the computer, it goes through the post, tells me the BIOS version, then proceeds to say "No device is found" and "BIOS is not installed". I tried going into setup and loading the defaults and rebooting, but the same thing happened. I would have thought the mobo would have come with a BIOS disk, but that stuff is all on CD-Rom, which, since I can't get into windows, is useless. It just goes through an infinate loop.
I've built many computers, and this is the first time this has happened. I was wondering if it was because I didn't F-Disk her drive before I put it in the new system, but that doesn't follow any logic to me. I tried using the 98 Boot disk already to see if I could go that route, but I get the "non-system disk" message when I do that. I do have a few hard drive utilities disks that will probably "wipe" the drive, but if that isn't going to get me beyong the boot messages, I don't see the point. I mean the BIOS isn't saved on the hard drive, so why do that?
I went to Soltek's website, and they don't list the 64 proc as one of their supported procs, which is silly since the board is a socket 754. Their Bios program says to create a bootable floppy with the award program, io.sys, and drvspace.bin, but the download only includes the award and update file.
How do I fix this problem?
